Introduction: The Random Facts of Life
You will never know everything about life, and you just have to accept that. But that doesn't mean you can't learn a few tricks...
Step 1: Cough Syrup
Everyone has had a serious cough, and the cough syrup doesn't always taste good. So instead of that store bought stuff just use some honey, honey is the most effective cough syrup around.
Step 2: Spider/ Mice Repellent
It is proven that spiders and mice HATE peppermint oil. So just get some peppermint oil in a spray bottle and spray all your doorways and your entire garage.
Step 3: Safely Pack a Razor
If you travel then you know an AWOL razor can cause some problems. You can fix that with a binder clip. Just slip the razor blade in between the clips and your stuff in your pack won't get cut up.
Step 4: Metabolism
To boost your metabolism just drink some water. Drinking 16 ounces of water will increase your metabolism by 30% .
Step 5: Slip Proof Coat Hanger
Some clothes have a habit of slipping off, especially coats and dresses. To fix this just slip a rubber band over the very ends of the coat hanger and your clothes won't slip off.
Step 6: Bake Tacos
When you fry taco shells they will fall apart when you bite into them. So instead bake your taco shells and they won't fall apart. Add some rice and cheese and you will never want regular tacos again !
Step 7: Bee/ Wasp
If a bee or wasp lands on you, blow on them. DO NOT slap them, if you blow on them instead then they won't retaliate.
Step 8: Stuck Zipper
To fix a stuck zipper just rub some graphite from a pencil on the teeth, that should do it.
Step 9: Ponytail Stash
If you have them then you know ponytail bands are not easy to keep track of. So instead of leaving them lying around put them around a carabiner and they won't get lost.
Step 10: Plane Tickets
Plane tickets are expensive but they could be cheaper. Tuesdays at 3:00 PM, six weeks before the flight is when tickets are the cheapest.
Step 11: Traveling Toothbrush
If you wanna keep your toothbrush from touching those grimy hotel countertops then just clip on some clothes pins and the tooth brush will lean against the pin and not the counter top. You could also use binder clips. But clothes pins will you give you a greater distance between the counter and the toothbrush.
Step 12: Un-tearable Paper
If you want to keep your papers from tearing then just slip some tape on the left hand side where the holes are. And the paper won't tear when it's in the binder.
Step 13: Cherries
Cherries contain antioxidants that protect the body from cancer cells.
Step 14: Apple Cider Vinegar
A tablespoon of apple cider vinegar in the morning will help with arthritis pain. WARNING if you drink apple cider vinegar straight up you could burn your throat !
Step 15: Oreo
Oreos are really good ! And most people would tell you to dip them in milk, but you could make Oreo cereal, pour some milk in a bowl with a spoon and plop in some Oreos, and now you have Oreo cereal
Step 16: Insta Protection in Seedy Areas
If you feel unsafe in certain areas then there is a quick trick. Download a police scanner app on your phone and listen to it at full volume.
Step 17: BACON !!!
If you run bacon under cold water before cooking then you will reduce shrinking by up to 50% ! Also, always cook bacon in an oven for 10 minutes at 365 degrees F for maximum flavor !
Step 18: Old Phone
If you have an old cell phone then keep it charged and in the glove compartment. All phones can call 911 regardless if they are activated on a specific network or not.
Step 19: End
Thanks for viewing ! I hope you enjoyed, please leave a comment and subscribe it tells me that you like the projects I am creating and want me to do more !!!
