Introduction: Monty - the Maker Faire Measuring Monster
We love going to Maker Faires, but 2020 has decided otherwise. So instead, we are building a suitable substitute called Monty, who will capture the atmosphere and share it with everyone.
Hardware:
- A Raspberry Pi
- A PIR motion sensor
- An Adafruit 4-Channel ADC ADS1015 (Analog to Digital Converter)
- A sound sensor (we used the Velleman VMA309)
- An Adafruit NeoPixel Ring
- A set of small screws
Monster:
- An old birdcage
- Fake fur
- Red paint for inside the birdcage
- 2 Plastic ornament balls
- 3 Round furniture pads
- White spray paint
Tools:
- Soldering equipment
- Strong glue
- Screwdrivers
- Needle and thread
- Cleaning supplies
Step 1: Project Video
Step 2: The Idea
In short, our project will travel to Maker Faire, measure the atmosphere using a number of sensors, save the data and return home, all whilst looking amazing.
With this idea, there are some things to keep in mind:
- International shipping: it has to fit inside a box, arrive safely and not cause any kind of panic, so you’ll be limited in weight, size and contents. To be on the safe side, it’s best to buy a box at your local postoffice and work from there.
- Plug & play: to limit the hassle at the event itself, the project only has to be plugged in for it to work.
- Privacy: we want to capture the atmosphere at the event, but not intrude on the privacy of the people attending it.
- Connectivity: reliable wireless internet is never a guarantee at events, so our device will have to function both online and offline.
That sounds like a fun challenge, let’s get to work!
Step 3: Setting Up the Sensors and Hardware
First things first, we’ll start by capturing the mood using a Raspberry Pi, a sound level sensor and a motion sensor.
We opted for these two sensors as you can get a bit of a feel of the event, whilst also respecting the privacy of the visitors. You can detect when there’s a lot of movement going on or none at all, without registering who walks by at what time. You can notice if it’s currently very quiet or really loud, without recording any audio.
Raspberry Pi
If you’re new to Raspberry Pis, there’s a great getting started guide here on the Raspberry Pi website.
Motion Sensor
To learn more about motion sensors and how to connect them to the Raspberry Pi, you can follow these steps in the Parent Detector Project by the Raspberry Pi Foundation.
Sound sensor & ADC
As the output of our sound sensor is analog, but the Raspberry Pi can only receive digital input, we’ll need to convert our analog values to digital ones using an Analog to Digital Converter (ADC).
Adafruit provides this great tutorial on setting up and getting started with their ADC breakout board right here.
NeoPixel Ring
What’s a monster without some pizzazz? That’s where a NeoPixel Ring comes in handy. To light up your monster, you can follow the steps outlined in the Adafruit NeoPixel Überguide.
Full Code and Schematics
Don’t worry if you don’t feel like following all these different tutorials to get your monster up and running, as we’ve added the full code and final schematics of this project to this step!
The code does the following:
- Import all the libraries and configure the hardware
- Every second:
- Change the color of the NeoPixel Ring
- Measure the noise level
- Detect motion
- Get the current time in Epoch
- Save the collected data locally to a JSON file (see next step)
- Every minute:
- Try to send the latest measurement to the Thingspeak IoT Platform (see next step)
To run your code on startup there's a fantastic guide right here.
Step 4: Data Collection and Sharing
One of the key elements of our project is that it shares its findings with the world, which is what we’ll jump into in this step.
Online with ThingSpeak
When our creature has an internet connection, it would be great if it sends the latest measurements to an IoT platform that’s accessible to everyone, like ThingSpeak.
To learn more about creating a ThingSpeak channel and collecting data with it, check out their getting started tutorial.
The code to send your data to ThingSpeak has already been added to the previous step, all you need to do is add your own API key.
You can check out the Montys channel here!
Wifi Credentials
Because Monty will be attending Maker Faire on his own, we’ll have to configure his internet access before he leaves.
If you happen to have the network connection details of the event, you can add them to your Raspberry Pi beforehand by following this guide written by the Raspberry Pi Foundation.
Offline with JSON
No need to panic if you don’t know the wifi credentials or if the internet connection is spotty, we’ll also save the data locally on the Raspberry Pi in a JSON file. This way, you’ll have a record of the atmosphere of the event that you can access the moment your measuring monster returns home.
If you’ve never worked with JSON before, W3Schools has a pretty good introduction here.
To analyse the JSON data, you can import it into your free data processing tools like the Google Data Studio or you can go nuts in R.
Step 5: Creating a Monster
Birdcage
As luck would have it, we found an old bird cage that nicely fits inside the biggest shipping box our local post office provides.
To prep it for monsterification, we cleaned it, removed the bird sitting sticks, figured out how to remove the cage bars and painted the insides red.
Hardware
After the paint dried, we attached the hardware to the bottom of the cage using a set of tiny screws. Make sure to leave a little bit of wiggle room, so there’s not too much tension on your electronics.
Monster
To create the monster, add plenty of fake fur! We glued a patch to the top of Montys head and hand stitched another piece to the bars of the cage.
For his three eyes, we spray painted the insides of two decorative christmas ornament balls white. We attached three halves to the fur on Montys head using some very strong glue. The finishing touches are three round furniture pads that function as pupils.
Step 6: Measuring Maker Faire
To round off our project, we designed a poster with a bit of an explanation about Monty The Measuring Monster to give the visitors of Maker Faire a bit of context.
Finally, we packaged Monty securely and shipped him off to Eindhoven Maker Faire. We really hope he survives the journey and has a wonderful time at the event!
If Monty has an internet connection, you can check out his measurements here on ThingSpeak. We’ll also keep you posted on his adventures via our Instagram and Twitter!
