Introduction: Recycled Pig
In this instructable you will be making a pig sculpture from large used container.
You will need:
- used round container with lid,
- 1.5 mm or 2 mm metal wire (about 2 meters in length),
- pliers.
The container in the photos was used to store Kalamata olives.
Step 1: Make Holes for Front Legs
Hammer in nails to make the holes.
Step 2: Make Holes for Back Legs
Step 3: Make Holes for Ears
Step 4: Make Hole for Tail
Hammer in nail to make the hole.
Step 5: Increase Holes Size With Scissors
Spin the scissors in clockwise and anticlockwise direction a few times.
Step 6: Make Back Legs and Tail
Put the metal wire through the holes to make the back legs. Spin the two ends metal wire at the top to make the tail. Use pliers.
Step 7: Wind the Tail With Pliers Into Spiral
Wind the tail with pliers into spiral and cut-off at the end.
Step 8: Make Front Legs
Put the metal wire through the holes.
Step 9: Make Ears
Put the metal wire through the holes. After that step you can close the lid.
Step 10: Make the Ears Sharp
Use pliers to squeeze the ears at the end. You are now finished.
Epilog Contest 8
Homemade Gifts Contest 2016
